Why does the compressor starter keep failing every two weeks?
Hi I have a Whirlpool Gladiator model#GARF19XXPK01. Manufactured 4/06. Quit cooling with fans on. Checked compressor according to videos. No shorts or opens.Replaced starter and capacitor and worked fine for two weeks. Starter failed again. I have gone through 6 starters and all have failed in the same amount of time. (2 weeks). Tried different companies trying to get different manufacturer but all are marked identical. Last one I tried was different. It is a RCO810. It failed in 10 days. Compressor is quiet when running and seems not to heat excessively. Refridge is completely clean. Fans, evaporator, condenser and vents. What am I missing?
Это хороший вопрос?
2 Комментариев
Is the refrigerant leaking? Do you have any air or water still in the lines?
из Dan
Hi Dan. No, no leaks. Everything seems to be normal until the starter quits. Have the thermostat on middle setting. Fridge is sitting in same place for 13 years so no blockage. The starters do rattle after they quit.
из butchjoiner
