Model A1224 / EMC 2316 / 2.26 GHz Core 2 Duo processor / Education only model. Released on March 4, 2010.
16вопросов Показать все
cant run high sierra
I tried running high sierra but it wouldn’t install so i assume that os is to advanced for it, which was the original os for this imac?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Here’s how to do it:
Requirements:
• Early-2008 or newer Mac Pro, iMac, or MacBook Pro:
• MacPro3,1
• MacPro4,1
• iMac8,1
• iMac9,1
• iMac10,x
• iMac11,x (systems with AMD Radeon HD 5xxx and 6xxx series GPUs will be almost unusable when running Mojave. More details are located in the Known Issues section below.)
• iMac12,x (systems with AMD Radeon HD 5xxx and 6xxx series GPUs will be almost unusable when running Mojave. More details are located in the Known Issues section below.)
• MacBookPro4,1
• MacBookPro5,x
• MacBookPro6,x
• MacBookPro7,1
• MacBookPro8,x
How to install macOS Mojave on Unsupported Macs
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
@obsoyeet - Your reaching! This series (A1224 / EMC 2316) RAM (8 GB) & SATA II (3.0 Gb/s) limitations really won't run these newer OS/s very well and you loose quite a lot of the features they offer which is why people want them.
из
OS-X El Capitan 10.11.x is the highest it can go, sorry ;-{
Your systems specs: 20” iMac 2.26 GHz Core 2 Duo (Mid-2009)
Оценка 2
Добавьте свой ответ
MATTHEW AREIZAGA будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 280
