Вопрос закрыт
iPod Touch is Disabled - Tried everything
I've gone through this site and I don't see anything that will help me with this issue.
My son in his brilliance added a passcode to my ipod and then forgot it. By trying over and over again to enter the passcode he got locked out.
Normally this wouldn't be a problem, but to add to my misery I got the blue screen of death on my computer and had to reformat the hard drive. I had to redownload iTunes.
When I try to put it in DFU mode, while I am holding the home button the apple logo appears as soon as I touch the on/off button. I've tried this 20 times, same result.
iTunes gives me this message...
iTunes could not connect to ipod Jodi because it's locked with a passcode. You must enter your passcode on the ipod before you can use iTunes...
iPod is disabled so I can't enter the passcode..
I would appreciate any help you can give me..
Thank you in advance
Jodi
Это хороший вопрос?
Оценка 0
Комментарии:
I finally got it to go to recovery mode
из
I held down the on/off button and home buttons the Apple Logo popped up right away, but I held the home button for approximately 10 seconds and it went into recovery mode. I think you have to cancel the other msg (iTunes could not connect to ipod Jodi because it's locked with a passcode. You must enter your passcode on the ipod before you can use iTunes...)before it will work.
I hope this helps someone else..
из
Добавить комментарий
1 ответ
try redsn0w or something to skip the itunes errors
make sure you download right version to flash thou
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,060
