I have a 1990 Ford Crown Victoria and the wipers keep cycling intermi
I have a 1990 Ford Crown Victoria and the wipers keep cycling intermittently even with the wiper switch removed. what's wrong?
Это хороший вопрос?
Это хороший вопрос?
This is most likely moisture on your logic board.
Remove wiper arms, cowl and cover from wiper motor.
I'm sure there are some YouTube videos on it. Clean, reapply dielectric grease and seal cover with rtv.
Also could need a board if cleaning doesn't fix it.
Был ли этот ответ полезен?
This is a 1990 dinosaur the wiper switch is removed from the vehicle. The wiper motor is brand new. When the key is turned to the run position or the accessory position the wipers cycle as if the switch was turned to the intermittent position. The switch is NOT INSTALLED it has been removed. Is there another device in the circuit that could be shorted out, or is there a problem with a short in the wiring
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 30
