My stain DC24 Does not have any suction when the canister is attached.
With the canister off I can feel suction but when it is attached there is not any suction to pickup any debris even light dog hair off of a tile floor.
Это хороший вопрос?
Это хороший вопрос?
Solution 1:
Air Filter
The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Solution 2:
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Solution 3:
Vacuum Bag
The vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Solution 4:
Vacuum Hose
Remove the hose from the vacuum cleaner, stretch out the hose so that it is straight, shine a bright flashlight into one end of the hose, and look through the opposite end of the hose. If the flashlight beam is not visible from the other end of the vacuum hose, this indicates that the vacuum hose is clogged or obstructed.
Solution 5:
Blower Wheel
Try turning the blower wheel by hand. If the blower wheel does not turn freely, check the wheel for obstructions. If no obstructions are present, the blower motor, not the blower wheel, is likely at fault.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 130
