How to place new Thermal Paste on Fujitsu Q738
I don’t know how place thermal paste on fujitsu q738
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi @wiwm ,
You shouldn’t have to refresh the thermal paste on your laptop yet. It’s only been out for a couple of years.
If there is an overheating problem with the laptop, there should be a 2 year manufacturer’s warranty on the laptop if you are located in Europe, the Middle East, India, and Africa.
Check the warranty statement that came with the laptop to verify what it is for your location.
If the warranty period is still valid, don’t void the warranty by opening the laptop. Get it looked at under warranty
Был ли этот ответ полезен?
Оценка 0
4 Комментариев:
But how do I opening the laptop?
из
@wiwm ,
I don't know as there is no information online about how to do it.
Why do you want to open it?
Is it overheating or what?
As I said the laptop is too new a model to have problems with the thermal paste this early in its life unless you are using it continually in very hot and dusty conditions, and it is labelled a "rugged" laptop so it should be built for this..
If still under warranty and there is a problem go the warranty route first.
из
The Laptop Is Overheating, I Don't Really Think The Laptop Have Thermal Paste
из
@wiwm m
Is the fan operating a high speed i.e. is the fan noisy?
Does this happen all the time or only when watching videos or playing games?
Use Task Manager (right click on taskbar and click on Task Manager and check what processes are using the CPU if the CPU is a high % .
Then find out what the processes mean by searching online for what they do and if they are necessary.
из
Добавьте свой ответ
Wan Isa Wan Muhamad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 87
