Screen Flickers and fans run very loud
Hi,
This is my first post here and with a big issue. Here it goes !
I have a mid 2011 iMac, which was full of dust/fluff and was getting hot very frequently, so I decided to give it a clean. I followed both the iFix video and used the “Apple Technician Guide“ to take it apart.
When I opened the Mac, it had a lot of dust and fluff. Some of the molex were really hard (maybe due to the age) and I’ve managed to brake 2 of them (really silly mistake) :
- skin thermal sensor on the logic board side (pads are intact)
- lcd termal sensor on the led backlight board side (pads are intact)
Because of this, I did a quick dirty fix to secure the cables in place using blue tac. Then, I tested the continuity, using a multimeter, between the wire and the board pads. Everything was fine, now.
After this, I sprayed carefully, using a spray can, everywhere and closed the computer.
When turning it on, there was nothing on the screen, it was black all the time. I could hear the chime, the optical drive starting and the hdd. All the correct sounds in the correct sequence but just a black screen and fans going like crazy.
I have assumed that the black screen was due to a bad connection somewhere and the loud fan due to the connectors I had broken. So I’ve re-opened the computer, re-attached all the cables and now I had Image.
However 2 strange things happened:
- the screen took a bit to turn one after the chime (5 seconds, maybe)
- the screen was flickering heavily and before concluding the boot process it went black.
Can the flickering being caused by the thermal sensor, or should the display work fine even without the sensor disconnected?
Please help me. I am out of ideas.
Thanks in advance.
Best regards,
Pedro
Update (04/15/2020)
I was wrong, LED1/ 2 have voltage, but LED3 hasn’t since there is no led3. On the connector side you can see that those pins don't connect to anything. Stupid me.
I have taken the backlight driver off and it seems ok to me. No burned parts, no capacitors leaking, nothing. However, I think this board has been repaired before, please take a look at the capacitor’s solders.
Is it normal for the power supply to output 11.40V instead of 12V?
Can I test the screen LEDs using an external power brick set to 12 volts? Will this work? This will be to mimic the driver's behaviour.
I hope it's not the lcd :-|.
Cheers,
Pedro
Update (04/27/2020)
I am suspecting I might have a problem with the lcds connector on the logic board.
After opening and closing so may times the computer, the lcds cable got damaged, in the end that connects to the motherboard. The 4th drag led no longer lights up and that means there is no communication between the logic board and the display.
If I’ve damaged the cable, it is likely that I have damaged the logic board’s connector as well. With the new cable, nothing changed. Led 4 is still off.
This is a picture of my logic board’s lcds connector (the picture from the front of the connector is really bad, so you cannot see inside)
Это хороший вопрос?
14 Комментариев
Sorry I don't see anything.
из Dan
@danj I posted as an answer, since replying to comments doesn't allow me to upload pictures. If you scroll you'll see a post with pictures
из Pedro Cardoso
@pcardoso73 - I moved it up as an update to your Q ;-}
из Dan
@danj
Thanks for that.
из Pedro Cardoso
@danj Can you, please, tell me what you can take from the pictures ?
And, regarding the voltage, is 11.40V ok?
из Pedro Cardoso
Показать 9 больше комментариев
