The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
107вопросов Показать все
Is Galaxy s10 plus replacement screen waterproof?
Or should I buy silicone around the corners ?
I’ve seen some people changing the whole front screen, taking out the battery and placing into the new screen. So the new screen should have adhesive inside already?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
No phone is 100% waterproof to begin with. If you want to change the screen and frame buy a samsung service pack as it will be the same as factory.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
What happens if you do not use adhesive to stick the screen back on?
из
It won’t stick
из
Samsumg S10 display replacement water proof yes ya
Оценка 0
1 Комментарий:
No it’s not waterproof
из
You can buy a replacement screen aftermarket, get it with the frame. It will be waterproof if you reseal the back cover. But that depends on how good your work is. You. Have to take the back cover off to take the phone apart to replace the screen. So it all depends on who puts it back together and if they seal it correctly.
Оценка 0
Добавьте свой ответ
Abbe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 3,952
