Changed front panel, battery indicator changes & turnes off randomly
I changed the front panel unit of my ipad air. When I turn it on now, the ipad turnes off automatically after a few minutes. Also, the battery indicator changes between 1% and 100%.
The repair worked well except for step 41 when I reattached the new front panel. I had the same problem as other commentators discribed: The cables of the new panel seam longer than the ones of the old one and “this side of the digitizer keep popping out.“, as @camerd33 discribed it as well. I don’t think this is what causes the problem with the batterie, though.
In step 35 I put two playing cards in between the battery and the logic board. May that have damaged the connection?
I did not reopen the ipad yet as I was hoping someone could give me a hint on what to look for specifically, once I do reopen it.
This is the link to the manual I used: https://de.ifixit.com/Anleitung/iPad+Air...
Update (24.04.2020)
As @hootonberg suspected I might have nocked out a component, I looked into my tools again and found this little square thingy of which I attach two pics. Might that be something that is now missing in the Ipad? Sorry for coming back to that question only now again.
Это хороший вопрос?
1 Комментарий
Oh, maybe its relevant that I used a fan to heat the sides of the ipad instead of the iOpener. I tried not to heat anything but the sides (not more than the white part) and not to heat it too long or too hot - but who knows. Also, the suction cup did not work at all for me. So I had to use some force to get under under the glas. Maybe I distroyed sth during that process?
из Anne
