PS3 no signal / boot after thermal compound replacement, GLOD
My console worked fine except it was very noisy.
I decided to change thermal compound and changed it with Arctic MX-4.
However, after I had my console assembled back I can’t manage to boot it up. It boots, but no video.
Green light is on, fan is working, USB ports have power on them, HDD indicator blinks at the start but then stays off.
Controller does not get recognized by console via wireless or cable, it just charges and flashes slowly.
The only way to turn PS3 off is by taking the power cable out. Sometimes it can be turned off by long pressing the power button (like 15 seconds).
I’ve tried:
1) Resetting video settings. No luck.
2) Entering recovery mode. It beeps twice but still behaves the same, so no luck.
3) Booting without hard drive (SSD in my case). Nothing changed.
4) Tried different HDMI cable, AV cable, 2 different TV’s. Zero changes.
5) Disassembled the console twice to inspect the board and if I forgot to plug something in. Everything seems to be fine and in place, but nothing changed.
I have reached the dead end and I have no idea how could simple thermal compound replacement end up in this disaster, what is the problem and what to do now.
Is there anything can be done about this or my PS3 is completely screwed?
Attaching some photos of my motherboard from both side. I’ve cut the HDD part of it but I can add it too if needed.
Это хороший вопрос?
