Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Touch-ID active but doesn't register my finger.
Hello, I recently have swaped my dock connector with a new one. everything workt fine (except for the dock-connector) and after the replacement my home-button stopt registering my finger, but does register my '‘press'‘ on the button with a vibration an action on the screen. when i try to setup my fingerprint it shows that i have to put my finger on the home button. an when i do that nothing happens…..
I have read that it could be give a message like, your home button is not acitvated, but my phone doesn’t give that message at all. and it also gives no vibration no action on the screen littery nothing shows up and i don’t no what is have to do in this case. so PLEASE help me!
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Выбранное решение
hi,
From experience, this can happen because of two things:
slight damage to The home button cable( the one from the display) or it’s not properly sitting in 100% flush with the board.
or secondary, the device needs a power cycle.
you can do this but disconnecting the battery, hold the power button for 5-10 secs, plug battery back in and force reset( hold power button and volume down) ( Apple logo will show up than the phone will shut off again) and see if that results in the home button working again.
I would also try a new display( if you have one spare) to see if the issue still persist.
this is with the assumption that you haven’t touched the physical touch button in any way.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
In addition, make sure your display cables aren’t bent severely.
This issues generally points to a display connector/display problem, should not be related to your replacement of the dock connector. That connector is a good distance away from where the problem could be. Inspect the home button display cable. If it shows any signs of damage, you would need to replace the display panel unfortunately which is a bit more risky given you’d have to remove the physical home button which is delicate and can easily be damaged if you don’t take your time with it. I’d try working with your current display first to ensure the connector seats flush in its connector and nothing small is blocking the connection. In the most rare of cases, this can sometimes arise due to a bad battery( not likely but it helps with the power cycling ). If you have a spare, it doesn’t hurt to try.
из
after some better inspection i saw that the ribbon cable of the home button was taped in place. after i removed the tape the ribbon cable was broken. so that was the problem. Thank you veryyyyy much for you help!!! now i have to buy a new screen :( but that is the only option a have right now. i wil be very gentel with removing the homebutton ribbon cable so that doesn't break aswell :) bye!!
из
You don't need to buy a new screen assembly. You only have to change the iluminator panel on the back of the display. It's not that hard to change it but it requires patiente and heat.
Оценка 1
Hello guys, hope everyone's ok. Well, I see that you all forget the fact that she could only renew the software, I mean restore it without back it up, could be a system bug. I have had one like that the only thing I have done, was a restore now it works fine….
Check that out and see if it could help
Stay safe guys
Оценка 0
same problem can not register my finger, just stuck. How to solve it?
can somebody tutor me? Maybe there are some video on youtube? Please help
Оценка 0
Добавьте свой ответ
Mika Bongers будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 234
