The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
364вопросов Показать все
Is the NAND chip on the Xbox One S replaceable?
I recently board an Xbox one s and it is missing the NAND Flash memory chip (Toshiba THGBMFG6C1LBAIL 8 GB eMMC NAND Flash) is this even able to be fixed?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Highly unlikely as the console uses per-console encryption for its firmware.
If the chip is gone and nobody has copies of the data on it, dead.
I can’t see why someone would pull the chip off as it’s pointless.
Был ли этот ответ полезен?
Оценка 3
4 Comments:
How would you be able to pull the data off of the chip?
из
Any NAND programmer that is compatible with this kind of chip should do, but it requires the chip to exist in the first place.
из
i have read the EMMC but it is encrypted
из
@digimod Not just encrypted, but per-console encrypted.
из
Добавьте свой ответ
Luke S будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 22
За всё время: 1,398
