Water pump system Ford Escape 2012 25 lt it's coolant close to the wat
It's leaking coolant near the water pump should I change water pump thermostat
Это хороший вопрос?
Это хороший вопрос?
More likely to be the water pump itself or perhaps a bypass or other hose nearby to the pump that is leaking. You need to visually confirm what is leaking with an inspection mirror and directing a strong light into the hard to see areas around that pump to see exactly where the water is coming from. There are also a lot of low prices boroscopes that hook up to smart phones these days that can help with tight inspection jobs like this.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 103
