The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
29вопросов Показать все
My ipad mini 5 bought in March 2020... Just a month old... doesn't c
My ipad mini 5 bought in March 2020... Just a month old... doesn't charges above 80%when charged in afternoon... In morning I use all 100%... Then I charge at 4.. to 5 pm in the evening ... But it only charges to 80%and doesn't charges above 80% ...
But in early morning when I charge it charges 100%...
Why is it so that it charges 100% early morning
and
'doesn't charges above 80% in the evening time...''
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
This is a battery management feature designed to extend the life of the battery. Keeping the battery charged to 100% 24 hours/day apparently chemically damages the battery. iOS will determine your typical use pattern and is supposed to only charge to 100% in anticipation of your use. Since you don’t use it at night, charge is limited to 80%; then, when your anticipated high-use time approaches it charges to 100% You used to be able to disable this feature; I just checked my iPad Mini5 under iOS 14.2 and that’s no longer an option.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Hiren будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 51
