Where is the blower relay resistor located
blower motor for ac and heat only works on high. where is the relay so i can replace it.
Это хороший вопрос?
Это хороший вопрос?
It is on the passenger side underneath the dashboard. Remove the cover first and you should see your blower. There is one screw that holds the blower vent to the blower. Remove that . Now you should see where the cable plug to the resistor. Anyhow, here is a great site that will show you more of the detail. Also some great info about your blower right here. About .com has a great image I attached it so you can get better detail. I hope this helps and good luck to you.
Был ли этот ответ полезен?
Is this answer for a Honda Element?
lovely24fan no. It is for a Dodge Dakota.
On the 2000 Dakota, the blower motor resistor is located under the center of the dash against the firewall. The dash does not have to be completely removed to access it, but it does need to tilted back in the brackets about 6 inches. Expect at least 2 hours for labor, it took me 4 for the entire disassemble, part exchange, and reassemble process. There is a PDF out there that explains the dash removal process.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 21
За всё время: 46,057
6 Комментариев
works on all speeds excpt high
из cool1mike
my blower worked and would work off and on and now does nothing. I will replace the blower relay resistor and see if that works.
из rortega12
I have replaced switch cluster and resister still nothing
из randy
mi carro Dakota mod. 98 me consume demasiado combustible ya cambie bujías
из Ismael Lopez
2002 dodge dakota I replaced the switches , blower motor and the resister still don't work. the new resister has three purple and two green wires don't match wires in truck don't know if they are wired right the fuses are ok,relays ok
из bruce
Показать 1 больше комментариев
