1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
191вопросов Показать все
Broken logic board header
Hey all,
I have a MacBook Air that's been refusing to charge and I noticed upon tearing it down that the 6 pin header for the I/O board has been ripped off the logic board, or at least that's what it seems. The header can be picked up to reveal 6 equal length pins soldered to the surface of the logic board. If I push down on the header with moderate pressure it completes the circuit and everything works. What are my options here?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
You can use a 60W soldering iron to re-solder the header back to the logic board. Use some good flux and some 60/40 solder wire. It will not be that difficult even if you haven’t had any experience in soldering.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Matthew Veitenheimer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 42
