Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
35вопросов Показать все
Is this logic board fixable?
Hello everyone,
Liquid entered my 2019 MacBook Pro 15" Touch Bar through the fans in the back and the following area of the logic board seems to have been burned (the case even contained black smoke mark). I’ve attached an image.
Is this fixable? Will I wil be able to retrieve my data otherwise?
Thanks in advanced,
~N
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 0
Добавить комментарий
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
1 ответ
Выбранное решение
The damage is part of the backlight power logic. This might be repairable! The reason I can’t give you a hard answer is it depends on what else is damaged and what is left of the traces. This will require some delicate surgery to repair.
As far as gaining access to your data on the system that too might be possible! You’ll need access to a second Mac which has Thunderbolt3 ports. Here we are going to leverage your systems ability to act like an external drive using Target Disk Mode:
Был ли этот ответ полезен?
Оценка 0
Комментарии:
Thank you. Nothing else seems to have been damaged. I've emailed Rossman Repair Group to see if the are able to fit it. If not I will try booting it up in Target Disk Mode and retrieve the data.
из
Добавьте свой ответ
Nicolas L будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 37
