Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1198вопросов Показать все
iPhone x won’t turn on after replacing the battery
Hi all,
I decided to replace my iPhone X’s battery after 3 years, the battery’s capacity is now 82%. I ordered from aliexpress a brand YILOZOMANA because I replaced my iphone 6s plus’s battery from this brand and it was good.
After I open the iPhone X to remove the old battery, I accidentally broke the haptic engine flex cable, I continued to put new battery in and try to turn it on but nothing happened. I tried again with the old battery but it still the same and the iPhone started to heat up quickly.
  1. Is it required a haptic engine to turn on?
  2. If not 1 then the logic board might be damaged because I tried with the old battery.
In case 2, is it still possible to fix it? I have ordered new haptic engine. I will try again when it comes.
Any help would be appreciated. Thank u for reading.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hello
1/ No the haptic engine is not necessary to turn on the phon.
2/ Do you tried to boot your phone with a lightning cable ? Are you sure that your batteries (old and new) are charged ? Replacement battery is sometime a lottery and a brand that worked correctly one day can be deffective in another batch. Find a good provider rather than a good brand (I saw fake Apple Battery : the brand is good… but it was a junk product)
Of course you can damage your mother by many different way but it would be surprising that you manage to do it if you were a bit cautious during battery disassembling .
I have notice that sometime when you disconnect the battery and reconnect it, the power button is not efficient and you need to boot with the lightning cable.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
mannguyen1 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 817
