iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904вопросов Показать все
Click to Access at Hard Disk
I have an iPod Classic 160 GB, but when I access it through the USB cable and iTunes to upload new music, the iPod clicks from the hard disk and access the hard disk takes a lot of time. How can I fix it? Thanks.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
This is just one possibility. You may need to defragment your hard drive. Your songs may be scatted all over your disk and it's taking a long time to locate them. TechTool Pro has optimize files and optimize volume sections that will do the job.. Others here may be able to suggest something better or some freeware to do the job.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Sounds like a bad hard drive, iut may not be completlly dead, so you should still be able to recover your media, but it will eventually die and need to be replaced.
Оценка 1
Thanks, but i try with TechTool Pro don't works on Windows. I hope you tell me another option to fix the iPod hard disk.
Оценка 0
2 Комментариев:
I'm sorry, I don't do windows. Maybe someone else can help.
из
Though this response may come late, when a drive is making actual "Clicking" noises, it's a hardware malfunction, and the best option is just to recover what you can and replace it, or ship it out to a data recovery company to have repaired.
из
Добавьте свой ответ
Frutiloopis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,715
