Both Fridge and freeze not cold, stay warm
My Whirlpool model GSF6C4XY03 side by side
The Freezer started defrost then stay warm, then the Fridge stay warm after that. I unplug it then plug it on back around 4pm, both Freezer and fridge start working back, ice is made. I leave it stay overnight and in the next morning, I saw ice is melted, both stay warm again, not cold at all. I have done twice and the issue is the same. Air is still flown from air duct which stay upper top inside freezer but the air is not cold like usual.
I replace relay, capacitor, clean the coil at the bottom and behind the refrigerator but the issue isn’t fixed.
Temperature is set up at standard : freezer 3F, fridge 37F.
I replace the Defrost Themostat by mr. Mayor help. It work well for 2 days. And then ice started melting and stay warm again, not make any cold in bold side.
When it works back, the cold air is blown out alot and strong.
please help me again. Thank you
Это хороший вопрос?
Hi,
Please verify the model number as the number you posted show no results?
Is the compressor still running when both the freezer and refrigerator are warm and the air is blowing warm or is it stopped?
If it is running is it hot to the touch?
Check for any oily deposits or residues under the compressor or on the condenser coils, (near the compressor) which may indicate that there is a leak of refrigerant
из jayeff
Model is GSF26C4EXY03. How can I know the compressor is running? The air is blowing like room temperatures
Thanks so much I will check everything. Then give you the answer
из Oanh Luu
