Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227вопросов Показать все
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
Это хороший вопрос?
Оценка 2
Добавить комментарий
7 Ответов
Наиболее полезный ответ
Sounds like replacing the battery would solve the problem.
Был ли этот ответ полезен?
Оценка 3
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
Оценка 0
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
Оценка 0
1 Комментарий:
please start a new post- just ask a question :)
из
Have you tried a soft reset first to get back to the startup screen?
Оценка 0
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
Оценка 0
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
Оценка 0
tell me what i cant do
Оценка 0
Добавьте свой ответ
cindy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 3,239
