The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
203вопросов Показать все
Can a faulty charger short out the device?
I have a charging station for my kids devices and 3 of the cables are micro usb's. As you can imagine, the cords get switched around quite a bit. A couple of weeks ago, their tablet stopped taking a charge. About a week later, the smart phone followed. Today, I hooked up my son's v-tec kid zoom watch, heard a click, amd then the device switched off. It does not appear to be charging now.
In the phone, I changed out the battery. That was not the problem. I purchased two charger ports to replace on the tablet and the phone, thinking the kids probably bent the ports… But after the experience today, I'm now thinking it was the charger itself.
Is this a thing?? If so, are the devices screwed? Or can they be repaired?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@cellis24 yes it is absolutely possible that a bad charger can do that. As for if the devices are fixable, that is a big depends. If it is the charger, then the concern would be that the powered management IC on the devices that stopped working, got damaged. Of course, it could be anywhere in the charging circuitry. You would have to check one device at a time and do some board level repair troubleshooting.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Cheryl E будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 124
