DC-in board is passing higher voltage than it should - not charging?
The machine was not charging - charger LED remains black when connected to the machine (tried multiple known good chargers).
Reset SMC, no change. Disconnected battery and connected a known good battery with some charge. Was able to power on and see battery stats, showed not charging with power adapter connected. Still no LED light on connected chargers, no charge being transmitted.
Replaced MagSafe DC-in board with two other DC-in boards, same issue with both.
Tested the voltage going through the DC-in board and it gives 19.5 V which is higher than the standard 16.5 V for the MacBook Pro (13-inch, Mid 2012).
Could this higher voltage be due to an issue with the logic board?
Note that the logic board appears to be clean (no clear signs of corrosion or damage).
Thank you for your help!
The following image shows the read-out from coconutBattery with a new battery installed and a power adapter connected to the MagSafe board.
Это хороший вопрос?
2 Комментариев
Hopefully your system is still running, please install this gem of an app CoconutBattery take a snapshot of the apps window and post it here for us to see Adding images to an existing question
из Dan
@danj Thanks. Added the screenshot to the question.
из Zach
