Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
64вопросов Показать все
Nikon d3200 no display backlight lcd has been replaced
bought the camera water damaged notice the only things not working are the flashtube and the lcd display took water damaged but only killed the backlight so I replaced it cant find signs of water damage elsewhere any ideas of what to replace next or where backlight is powered from etc?
Это хороший вопрос?
Оценка 0
1 Комментарий
Camera functions as should just backlight and flash do not work I can shine a flashlight on the lcd and its on live view works just seems to be no power to backlight brightness is set to max
из
Добавить комментарий
1 ответ
Выбранное решение
@danield1497 since this is a water damaged camera it will most likely be an issue with the mother board. Check for any obvious components mossing or charred looking. There should at least be one fuse on the board.  Check that one for continuity. Remove the motherboard and clean it with some +90% isopropyl alcohol and a soft brush. Yes, you can submerge it in alcohol to clean it. Post some good images of your motherboard so we can see what you see and possibly find the failed part.
Nikon D3200 Motherboard Replacement
Adding images to an existing question
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Nikon D3200 Motherboard Изображение
Инструкция
Сложность:
Модерировать
15 - 30 minutes
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
daniel durant будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 164
