Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
71вопросов Показать все
How can I access my phone if the screen is broke?
I need to get my files off of my phone, but the screen is cracked (very fragile thing) and the screen isn’t showing up. So obviously I wont be able to press “allow” to let the computer interface with the phone storage. What can I do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You could put the motherboard into another phone and extract the data and remove it. The only cost will be time and possibly a 80 cent adhesive strip to reseal the battery cover. Or you can put a new screen on it. You can buy a new screen for around 200 to 250 dollars with frame. And I would buy it with frame. You might also get a new battery cover because if you aren't good at taking these off they are easy to break. But the cover is less than 5 dollars. All you will need is a heat gun or a hair dryer a pair of tweezers, a plastic spugger and a mini Phillips screwdriver. Ifixit has videos and there are a lot more on YouTube. You can either keep the phone or sell it and buy something else.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Bobby John Ford будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 63
