Released in March 2017, the Moto G5 includes a 13.0 megapixel rear camera, a 5 inch screen with a 1920 x 1080 resolution, and the Android 7.0 (Nougat) operating system. Identifiable by the model numbers XT1675 and XT1676
27вопросов Показать все
Water damage on the moto g5
My gpa fell into a lake, and broke his phone. I took it apart, cleaned a lot of it with isopropyl alchohol, and it is still stuck in a boot loop. It flashes the android thing, then turns off, then on again. Should i just put the whole phone in a bath of isopropyl alcohol or just try to use a q tip and clean it with alcohol?
Это хороший вопрос?
Оценка 0
1 Комментарий
I can send images if that helps any. Thanks in advance!
из
Добавить комментарий
1 ответ
Выбранное решение
You can put the motherboard in alchohol and clean it with a qtip and a soft brush but if you are able to get it to turn back on it could stop at any moment. Once it's wet it's not worth fixing except to extract data. Not repair shops will take them in except to retrieve data.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Yep, all i want are the pictures. He forgot to back them up. Thanks!
из
Добавьте свой ответ
Dylan Devries будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 160
