Released in March 2017, the Moto G5 Plus (model numbers XT1687, XT1680, XT1684, XT1685) includes a 12.0 megapixel rear camera, a 5.2 inch screen with a 1920 x 1080 resolution, and the Android 7.0 (Nougat) operating system.
54вопросов Показать все
Is it ok for me to put the entire logic board into isopropyl alchohol
Is it ok for me to put this entire logic board into 70% isopropyl alchohol? Its a last ditch effort to save puctures
Это хороший вопрос?
Оценка 0
6 Комментариев
also how long should i let it sit there
из
any help would be nice
из
@Dylan Devries
70% isopropyl alcoholis to to disinfect like for Covid-19 bought at pharmacy.
100% isoprophl alcohol (no water) is for cleaning electronics bought at electronic store.
Remember - highly flammable !!!
But before using alcohol would you answers these questions as you did not really say what your problem was ?
* What happened?
* You wrote "...save puctures (picture I guess?)".
* Are they not on your SD card? Please explain.
* And why do you think alcohol will help?
из
Sorry, My grandpa fell in a lake, his phone was wet, and got stuck in a bootloop. I fixed it by using 70 percent alcohol because everyone around me is making hand sanitizer with it. He had no SD card in it. Alcohol is meant to displace the water, and i used it because he needed his pictures back. It ended up being the battery that was causing the issue
из
Hi @Dylan Devries ,
Glad to hear you solved the problem. Your grandpa was very lucky.
из
Показать 1 больше комментариев
Добавить комментарий
1 ответ
Выбранное решение
I believe it would be ok, submerging in rubbing alcohol is a standard practice, let it sit for an hour or two and it may solve your problem.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
is 70 isopropyl good enough to do it? Every other type is sold out everywhere
из
90% or above is whats reccommended but if you wanna take the chance it could still work.
из
thank you so much
из
Добавьте свой ответ
Dylan Devries будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 98
