Charging port not snug
The charging cable is very loose in the phone charging port. Can I get parts to replace the port on my Droid Turbo Power/
Это хороший вопрос?
Это хороший вопрос?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 44
Did you check with a different cable? micro-usb is kind of designed that the cable fails rather then port. If still problem:
Search in eBay (depends on the country)...
из Markus2
@markus2 Thanks for your answer. I have tried other cables and still have the same problem. The cables work on other phones.
из Robert Bruns
Well then in eBay.com you can find the charging port around $4. Of course, there are perhaps no manuals for charging port replacement: Start with Motorola Droid Turbo Battery Replacement
May be it helps.
из Markus2
