Support and repair information for JBL E25BT wireless in-ear headphones.
Вопросов 19 Показать все
Why aren't the earphones charging?
When the earphones are connected to the charger the usual white light switches on and stays like that for 2 seconds and then disappears again. This happens every time I plug it in. The usual light disappears after 2-3 seconds.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Try reseting them.
  • Power off your earphones.
  • Press and hold the power button for more than 5 seconds.
  • The light will blink and then you’ll be notified.
  • Pair it with any new device.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
They aren't powering on. The only light I see is the white one which stays for 2-3 seconds just after plugging it to charge. I tried holding the power button for 10+ seconds but there was no indication of them resetting.
из
@Miz Uh oh... Have you tried powering them from a different source?
Also, are you in warranty? If not, note that opening this to diagnose with a polymeter is a really delicate procedure.
из
Добавьте свой ответ
Miz K будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 189
