How to adjust the headlamps on my 2007 Dodge Grand caravan SE
Это хороший вопрос?
Это хороший вопрос?
Apparently ther are different HL out. Let us know if you have the one with a "Bubble" window. Kind of like a Level :-) If you do not have the bubble one then there is no horizontal aiming adjustment. Horizontal aim is preset and does not require adjustment. tTo adjust headlamp vertical alignment, rotate adjusting screw to achieve the specified low beam cut-off location. the adjusting screw is shown in the attached image. Hope this helps.
Был ли этот ответ полезен?
Okay. So there is no easy adjustment. I guess I need a difficult one.
Maybe my adjusting screw is broken. It only moves it a small amount before it stops moving. How do I find that adjusting screw shown in the attached image
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 5,036
