Mac mini 2011 won't boot and vertical lines.
My macmini is suddenly got verical lines on screen. And then problem with start up. I cannot go to recovery Mode. I can go to safe mode. But i don’t know what to write there to be able to go to recovery mode again. When i go to recovery i see the globe but after the indicated time is finished the screen turns to white. Can anybody please help me what to do? Thanks in advance.
Это хороший вопрос?
6 Комментариев
Can you tell us which model you have Apple produced two versions:
● Macmini5,1 - HD Graphics 3000
● Macmini5,2 - Radeon HD 6630M GPU
из Dan
Hello Dan, thank you. Can you please tell me where can I see that.? Because I cannot go to the computer. It can not boot correctly. I have the box. The model is A1347. Is it this one? Or can I see it from the safe mode? Please help me on this. I am not very familiar with apple.
из Macminime
Locate your systems S/N from the system and plug it in to here EveryMac - Lookup
If you can get into Safe Mode then look at the About This Mac and then click on the System Report button click on the Graphics/Display section you should see one or two Video Cards listed.
из Dan
I have the box. On the box i see that the s/n begins with CO
Macmini is 2.5, BEL/IEA. Can these information be needed to see the graphic card model. I will also try to single user mode (control s) to give you more details. I also did a hardware test that said no hardware issues found. Is that a good sign or not. Idk. But still vertical lines appearing and no recovery mode able. I appreciate your help.
из Macminime
Command s and i see just bunch of lines (like dos in windows) and then i have to write syntax language. My question is if i cannot solve the problem with syntex, which syntax command should i write to have at least the recovery mode back? Is that possible? Because i have no access to recovery or whatever but this. Thanks in advance
из Macminime
Показать 1 больше комментариев
