Battery Is Not Charging
new battery
new charging wire
new charging port
i have voltage in battery connector on motherboard
SMC reset
GPU - switch off
but... no battery charge, no light on charge wire, can't start without battery.
Plug\unplug charger: https://youtu.be/7rnb9v6DNEo
Battery Information:
Model Information:
Serial Number: D861015004NDGDL3T
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 2
Hardware Revision: 00aa
Cell Revision: 2
Charge Information:
Charge Remaining (mAh): 544
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 7800
Health Information:
Cycle Count: 1
Condition: Normal
Battery Installed: Yes
Amperage (mA): -25
Voltage (mV): 11350
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
GPUSwitch: 2
Hibernate Mode: 3
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 0
Battery Power:
Display Sleep Timer (Minutes): 2
GPUSwitch: 2
Hibernate Mode: 3
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 0
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Charging: No
Это хороший вопрос?
