How to replace cracked LCD?
So this screen had a small tumble and the cracked screen seems to have damaged the LCD panel. Any tips on parts/tools to repair it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Unfortunately, Dell has never repaired monitors, sold monitor components, or have monitor disassembly documentation. Short of finding a seller of panels on eBay, there is not much that you can do.
Был ли этот ответ полезен?
Оценка 2
Last year my company bought one DELL U2719D Monitor and after a few weeks usage once when I gently griped its black bezel on the left side in order to tilt it a bit more for a more convenient angle the display has been broken along a thin line and discolored similar like the images above show it. I am very dissappointed as I used it the same way as any other raized bezel monitor before, furthermore I've been working with Dell workstations for long years without any hardware isue. The supplier and Dell service manger in Hungary doesn’t want to admit this design error.
The question has been still in my mind that why these sharp but weak bezeled constructions are legal to be on the market while it can damaged with a care gesture too. As an industrial designer I can’t believe that an everyday used piece like this how is designed and licenced to the market without any gripping part or a strengthened bezel.
The Dell in USA cannot be contacted from the EMEA (Hungary) to ask for their formal opinion on this fundamental design defect. Anyone knows a direct contact to the Dell's stakeholders, please give me. Thank You.
Оценка 0
1 Комментарий:
I know this is an old post, but I entirely agree - for the price of these monitors it is very disappointing. The thin bezel is very nice aesthetically but must be reinforced with a metal frame behind it. The only rigidity at the edge of the monitor seems to be from the LCD panel itself rather than the case, which is insane.
из
I had this issue exept it wasnt accidental as i had the funny gamer rage and only broke the LCD panel. Backlight works fine and ive started using it as a light table. If you want to turn your Dell U2717D into a light table email me mcdowblie@gmail.com
Оценка 0
Добавьте свой ответ
Qui-Gon Jim будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 18
За последние 30 дней: 99
За всё время: 3,213
