If I replace battery the iPhone is still water resistant?
Hi,
I need to replace battery for my 7 plus if I open the device is still water resistant?
thanks!
Это хороший вопрос?
Hi,
thanks!
Это хороший вопрос?
In theory, it should still be “water resistant “ after you replace the battery (this if you also replace the original adhesive).
But in reality, it probably isn’t going to be 100% “water resistant“, it’s extremely hard to get a perfect seal that stops all moisture. I wouldn’t even trust that it really is that when it comes from the factory.
Depending on how you manage to place the new adhesive, it should work to stop most moisture to come into the device.
But I would recommend using a waterproof case if you are planning on taking a swim whit the device on you or something like that when you have the device underwater for a longer period of time (this even without opening the device up).
Hope this answered your question. :D
Был ли этот ответ полезен?
It can, if the job was done properly.
However you have to make sure other water resistant parts have not degraded, which is very hard for a phone this old.
За последние 24часов: 1
За последние 7 дней: 19
За последние 30 дней: 67
За всё время: 3,686
2 Комментариев
I replaced my iPhone XR battery is this will be water resistant
из Maaz Amin
@Maaz Amin
Not as good as when it left the factory
See the answer below.
из jayeff
