Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
41вопросов Показать все
What adhesive tape to use for Surface Pro 5?
I am replacing the battery on a Surface Pro 5 and re-using the screen assembly.
Does anyone know what type of adhesive tape would be best for re-assembly.
I want to find out what is close to the factory tape in thickness, adhesion, and type as possible. Any recommendations would be greatly appreciated!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I’ve always used Tesa tape brand (link below) with excellent results. Its the right thickness and holds very well.
I mostly use 2 and 4 mm.
Tesa 61395 Tape
Tesa 61395 Tape Изображение
Продукт
Tesa 61395 Tape
$5.99
Был ли этот ответ полезен?
Оценка 1
Комментарии:
Perfect, this is what I have on hand from a previous Surface Pro 4 repair.
Did they change the tape to a thicker foam type tape for the Surface Pro 5?
I thought I read somewhere that it's different the previous models.
из
That I do not know. I've just had great look with Tessa tape on all repairs that either dont come with precut adhesive or need a little bit more applied.
из
Добавьте свой ответ
William Blalock будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 484
