keeps saying code 08 but it doesn't have a reset button
Ok I bought a colman saluspa hot tub and it keeps saying code 08 but it doesn't have a reset button on the pump so is there anyway I can reset without that button?
Это хороший вопрос?
Счет 1
4 Комментариев:
Hi ,
What is the model number of the spa?
из
Tried fix but still doesn't work. I have a similar model without a reset button on the side. Every video I've looked at shows only models with reset buttons. What's up?
из
@tiborouyang
What is the model number of your hot tub?
из
Добавить комментарий
2 Ответов
A search pulled up that the code requires a thermal reset. This video shows the power switch being used, along with the GFI test button on the pump cord, not on the pump itself. Here's the link:
https://www.youtube.com/watch?v=isgLwdtb...
Был ли этот ответ полезен?
Счет 0
There is a reser button, it just depends on the model number where its located. Refer to the owners manual for your unit. It is available online in a pdf ,if you no longer have it.
Счет 0
Добавьте свой ответ
Heather Griffith буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 19
За всё время: 3,646
