Guides and support for various television (TV) brands and styles.
9024вопросов Показать все
How to tell if TV backlight inverter or backlight array is broken
sharp LC50LB481U
The TV originally led would flash and not turn on but I did a factory reset and now it turns and has an image if a flashlight is shone at the screen. I'm trying to figure out if it is the backlight array or the backlight inverter is there a way to test and see if it is one or the other. the parts to repair both are pretty expensive and don't want to have to buy both if only one is broken
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
https://www.shopjimmy.com/sid-gj2c-led-t...
plenty of videos on how to test leds. this tool will help. can find them cheaper online and more videos on how to test without removing the strips on you tube. easier than testing inverters.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
11908649 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 288
