Модель A1418 / середина 2014 г. / процессор Core i5 с частотой 1,4, 2,7 и 2,9 ГГц или Core i7 с частотой 3,1 ГГц
How do I upgrade my mid 2014 21.5 iMac?
Hello, I have a mid 2014 iMac 21.5 inch and was wondering how much I can upgrade? I only have the 1.4 GHz Dual-Core Intel Core i5 cpu. I want to upgrade everything to make it last as long as possible. can I put a 4k screen in?
Это хороший вопрос?
Счет 0
1 Комментарий:
Добавить комментарий
2 Ответов
  • This systems RAM is soldered! So you are stuck with the 8 GB it offers
  • If you have a HDD model you won’t have the PCIe blade SSD connector and its support logic so that rules out any performance improvements by adding a faster SSD drive
  • The CPU is also soldered down so you can’t upgrade it
  • This system can’t support an internal 4k display either!
Basically, it is the least upgradable system Apple made!
So the only thing you can improve is swapping out your SATA III (6.0 Gb/s) HDD to a SSD. Here’s the guide to do that Замена жесткого диска в iMac Intel 21.5" EMC 2805. If you have a PCIe blade SSD only system you could add in a HDD or a second SSD.
If you happen to have gotten a Fusion Drives system then you could replace the impish 128 GB blade SSD to a more sizable blade SSD (500 GB to even a 1 TB) as well as breaking the Fusion set so you end up with a true dual drive setup which will get you even better performance! Замена blade SSD в iMac Intel 21.5" EMC 2805
Frankly, I think finding a used Mid 2017 21.5” would be a better and cheaper direction iMac18,2 - 21.5” 4K iMac Core i5 3.0/3.4 GHz or a i7 3.6 GHz as you are also looking for a 4K system.
iMac Intel 21.5" EMC 2805 Жесткий диск Изображение
Инструкция
Сложность:
Умеренно
40 minutes - 1 hour
iMac Intel 21.5" EMC 2805 Blade SSD Изображение
Инструкция
Сложность:
Умеренно
30 minutes - 1 hour
Был ли этот ответ полезен?
Счет 0
Hey Dan,
Thanks for this post! I also got a mid2014 imac (i5 CPU) recently and i was wondering if I could swap out the internal components with another imac that was damaged?
Thanks in advance.
Счет 0
1 Комментарий:
Best to create your own question listing out what you are thinking of re-using in the other system. Make sure you tell us the exact models involved
из
Добавьте свой ответ
Nick Crill буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 21
За последние 30 дней: 57
За всё время: 10,702
