After replacing screen my proximity sensor no longer works
Everything works except the proximity/light sensor. I downloaded a sensor app to see if it is even working but it says that it can't be detected.
Это хороший вопрос?
Это хороший вопрос?
hi everyone, im new member in here. i have the solution for google pixel after replace the screen, proximity sensor not working. i’ve been fix this many time and works
you can use ruber from iphone 6 proximity and covered it to google proximity sensor.
may this solution help you guys
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 218
Maybe the sensor did get not attach properly after repair, or got damaged in the proccess. Did you do it yourself or did you have it done by a third party?
из Med_tech
I did it myself and everything went smoothly. Which one is the sensor? I want to open it back up and check.
из Justin Chang
