How do I fix the battery latch door will not stay close or to lock
- how to i fix the battery door mlatch will not stay close or lock
Это хороший вопрос?
Это хороший вопрос?
Hey Richard Francis is that a slide lock latch? One way would be to checkout ebay for the model you have but broken and see if you can use the parts off it to fix yours. Cost is relatively low and trying to find parts on those are hard and most likely no one has them.
Был ли этот ответ полезен?
Hey Richard, I’m now in the same boat as you (were). Did you figure out how to fix it or where to get the part?
I found one on Aliexpress
If anyone has this issue, your battery door/ latch cover is broken and needs to be replaced.
You do have to unscrew the camera housing and sort of take it apart in order to reach the latch. 5 screws outside the camera carefully remove the cover and once inside, remove the 2 black screws holding the metal tray. Tilt LCD out of the way and lift the tray a bit so that you can unhook the latch. Remember to take pictures when taking it apart just in case.
Here is a link to the part for a st76 camera
https://www.aliexpress.us/item/325680448...
Here is a link to a tool kit that worked for me
За последние 24 часов: 0
За последние 7 дней: 15
За последние 30 дней: 47
За всё время: 709
