Google's third-generation Pixel-branded smartphone, and their first "notched" phone. Comes with a 6.3" QHD+ OLED display and 64 or 128 GB of storage. Available in Nearly White, Just Black, or Not Pink.
77вопросов Показать все
Mic doesn't work after charging port replacement
I replaced my charging port with an iFixit replacement. After putting back together everything works as expected except for the mic when not on speaker phone. From my research, the mic is part of the charging assembly. I am wondering if I received a defective part? I am going to take apart again in check all connections. I’m wondering if anyone else has suggestions…
Thanks!
Это хороший вопрос?
Оценка 3
3 Комментариев
Hi. what was the solution for your problem ? have exactly the same problems…..
из
I did another charging port change and the mic works fine now. It's likely the board I received was defective since the connector seemed seated fine for the faulty board. I was able to perform an exchange to receive a new board. After installing the new board, everything works fine now
из
Ok thanks. I think i have the same problem. Ordered new board to test it.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I would imagine it’s defective. Disassemble and check the connection. Sometimes if it’s not seated all the way it won’t work.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I replaced the charging port with a new replacement and the mic now works. I can confirm that the part I used previously was simply defective.
Thanks for the suggestion
из
Getting another replacement daughter board should fix the problem because some replacement board has faulty mic from factory.
Оценка 0
Добавьте свой ответ
SEAN BEAUSOLEIL будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 596
