Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Home button doesn't always work.
My home button works randomly, sometimes it works as it's supposed to other times I have to push it 5x or more to get it to respond
Any ideas
Это хороший вопрос?
Оценка 2
2 Комментариев
What model do you have? 2G, 3G, 3GS or 4?
из
Sorry, forgot to add it an Iphone4
из
Добавить комментарий
9 Ответов
Выбранное решение
This is a known issue with all iPhone models. If you are still under the hardware warranty Apple will replace it no questions asked, I had mine replaced 2 moths ago. If it's a model that's out of warranty then you either have to deal with this problem, or replace the home button.
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
I had mine replaced as well about 6 months after I bought it. Mine had also stopped working for no apparent reason.
из
Yeah Scott, this is why I was hoping they do away with the Home Button in the iPhone 4S/ iPhone 5 model. ;/
из
Наиболее полезный ответ
Step 1: Navigate to, and launch one of the stock applications on your iPhone. If you don’t already know, the stock apps are things like weather, YouTube, stocks, settings etc (any that come as part of iOS).
Step 2: When the app is launched, press and hold the Power button located at the top of the device until the ‘Slide to power off’ appears.
Step 3: Press and hold the iPhone home button. Keep the button depressed until the Slide to power off slider disappears and the application quits back to Springboard.
Step 4: Voila! Your home button is now re-calibrated and should be more responsive for you.
Оценка 7
I take a few drops of 91% alcohol and work it in around the home button by rotating my finger around the perimeter of the button pushing it down and letting the alcohol seep in around the button and pressing it repeatedly. I fix alot of these without even opening the phone.
Оценка 3
Just to correct a few answers here, the home button consists of two parts. The home button itself (plastic circle) and the home button flex. The issue with your home button is the flex, a very common issue with iPhone 4's. All you will need to do is replace the flex ribbon and you will be good to go!
That said, if it is still under limited warranty then you should take it to apple to organise a free replacement :)
Оценка 2
@dsq Ohhh. Thanks!! That actually did work!!
Оценка 0
Home button fixed!
Date: 8-30-12
Fixed by: Replaced home button for $15:
[связанный продукт отсутствует или отключен: IF182-017]
Final comments:
I am actually shocked that Apple would allow its home buttons to wear out over time!
I would have expected Apple to have better quality control and tests for the number of clicks the home button could take - ideally I feel as if it shouldn't ever wear out!
My Journey...
My issue:
Home button only worked when pressed on the bottom half (or bottom 1/4), which typically resulted in the home button ignoring me all together, or only registering 1 or 2 clicks, or 2 of 3 clicks (resulting in a completely different behavior). This is particularly annoying if you use Activator (libactivator) for different actions... or simply use the App Switcher a lot.
Attempts (all failed):
1. Cable push up:
http://www.youtube.com/watch?v=OXlY-Vcxb...
2. Home button "recalibration":
http://www.idownloadblog.com/2011/12/22/...
3. Brought it to an iPhone repair shop (uBreakiFix), and they claimed to fix it
- It didn't work any better or any worse
4. Applying more pressure:
http://appstouse.com/solved-damaged-ipho...
5. Rubbing alcohol (and windex) cleaning the entire button and contact (after disassembly to the point of LCD removal to actually access the home button intself)
6. Repositioning, removing and replacing the flex cable into the slot
Work around:
Enabling AssistiveTouch in iOS5 (but it was inconvenient to use)
What fixed it:
Upon inspection of how the home button actually is supposed to "click" it looks like it was internal in how the button is put together, and then the flex cable reads the click and sends it to the OS accordingly.
This, and seeing the comment here - Home button doesn't always work.. from martin, made me order a new home button from iFixit.
After installing it, it worked perfectly!
Оценка 0
Just like to say a huge thanks to Craig, I used anti bacteria hand rub (the only high % alcohol I had in the house) rubbed it in a few times and it now works like brand new!
Оценка 0
@ appexe You're shocked that apple would have a faulty home button ?? It's a crappy company... all they want is you're money. They give the illusion to consumers that their products are high end. But it's made in China just like everything else. Its like the Power PC G5 I bought then they switched over into INTEL chips.. I think I had Apple Support for another year or so and then they stopped. I spent all that money for a High end apple only to be able use it for a short time.
Apple has lost me as a customer.
As far as the phone goes you can buy a Home button on ebay for cheap. If you're handy with tools you can replace it yourself.
Оценка 0
I think you can try to open up a stock app, like the Clock. Hold down the sleep button until "Slide to power off" appears. When it does, let go of the sleep button and hold down the home button. After about 5-10 seconds, the app will close.
Оценка 0
Добавьте свой ответ
weez1965 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 22,808
