Belt clip remote control Not working. Does this have a battery?
I have a 2nd generation A1019 ipod with a belt clip remote control that doesn’t control the ipod any longer. Does this device have a replaceable battery?
Это хороший вопрос?
Это хороший вопрос?
No, the remote control does not have a battery. You can try cleaning the metal contacts on the connector with a q-tip and rubbing alcohol.
If it still doesn’t work, you may be able to find a replacement - but be careful, some of them have a different connector that doesn’t work with the 2nd generation iPod, even ones that are listed as working for the 2nd generation. Make sure that that the connector is the same as the one you have.
Был ли этот ответ полезен?
Thank You Daniel, Didn't want to destroy it trying to fix it. Will try this Thanks Again.
also make sure the little lock switch on the side is showing green not orange.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 65
