It will not get channels I have cable from wall
My TV has only one channel i tryed everything
Это хороший вопрос?
Это хороший вопрос?
Hi Kiana Flores
It would be good to share where and which country you are located, so
Just to check when you do a full channel scan, it only show one channel? how about other tv? had you test the outlet with another tv?
https://www.manualslib.com/manual/169081...
In rare case if the tuner could be faulty and the hdmi ports are working well, you can consider getting a set top box to receive channel and connect to hdmi port
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 59
