Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
82вопросов Показать все
MacBook - won't charge with USB C-C cable - charges fine with USB A-C
Apple branded MacBook charger (30 W) with USB C to USB C cable recently stopped working on my MacBook. No visible damage. But it will charge my phone, so the charger isn’t dead and the cable works.
Apple branded iPad charger (10 W) with USB A to USB C cable does charge the MacBook, albeit slowly.
Anker branded charger (two ports, USB A and C) - this will charge my MacBook but only from the USB A port (the USB C port works fine with other devices).
Any idea what could be broken and (better still) how ifixit?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Unsure if this is the solution but the 12 - inch Macbook should have come with a 29W power adapter. It sounds like you are using a 30W meant for the MacBook Air. Try using the recommended power adapter with the MacBook.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I hear ya, but the 30 W adapter has been working for months. I feel like the answer's somewhere else. Thanks though.
из
Добавьте свой ответ
jak будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 96
