The MSI GE62 6QF Apache Pro can be identified by its model number: MS-16J4. It's a high-end gaming laptop that was released in February 2015.
8вопросов Показать все
Help, I want to know what kind of transistor or mosfet this is.
I'm using a translator. Please understand.
My laptop fell to the ground, and the audio circuit parts fell off.
So I'm trying to replace the part, but I don't know exactly what it is.
It looks like a transistor or a mosfet.
Because the leg of the part is broken, I won't solder it with that part. Just tell me exactly what that part is.
ge62 schematic : https://www.badcaps.net/forum/attachment...
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
These three-digit SMD markings are not very reliable to ID components. A quick search for a 751 sot-23 yields results for a zener diode, which this chip clearly isn’t. Why not instead try looking up reference designs for that audio IC? A lot of times the manufacturer just uses whatever circuit the IC manufacturer recommends.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
That is a good idea. I'll give it a try. Thank you!
из
AO3404 sot23
i think this is it.
из
Добавьте свой ответ
[deleted] будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 152
