any advice on fixing a broken 3.5mm audio jack?
I bought 2 Lenovo 300e Chromebook for my kids, and now one of them has a broken 3.5mm audio port. I’m trying to use it with an external headset for distance learning, and the headset speakers work, but not the mic. Any suggestions?
Это хороший вопрос?
3 Комментариев
I have just had one of these in , the socket is very easy to remove with a standard soldering iron and solder sucker. Just need to found a replacement socket now.
из Glenn Allen
It looks like you can order them off ali express. The closest one I can find is 5pcs/lot Audio Combo Jack Connector for Acer Ausu Dell HP Lenovo Laptop Headphone Microphone Port , PCB to Top H 1.8mm
https://www.aliexpress.com/item/32614729...
I will check what else i can find and let you know what I got to fix it in the end.
из Glenn Allen
Thank you Glen!
из mike
