Changed the battery, can’t use computer now
The trackpad won’t work and fan just keep running
Это хороший вопрос?
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
Your fan will run hard when it looses access to one or more thermal sensors. To identify which one I would install this great app TG Pro
In the process did you damage something?
Комментарии:
Yea I think the track pad wire might of broke or something.. it is not connecting... any solutions ?? I ordered the wire for it
Are you having a problem with the cabled connector on the logic board or did you damage the cable its self? Here's the needed part MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad Cable and here's the guide you'll need to follow as you'll need to take the battery out to gain access to the trackpad unit to replace the cable MacBook Pro 13" Retina Display Late 2013 Trackpad Replacement
из Dan
Go to step 42 in the track pad replacement thing... I broke the black part in it
Hey I got it work thanks Dan and everyone for the help... is it possible to change the ram on his model ???
Did you put the clamp back on? If not it won't be stable without it.
Sorry no you can't alter the RAM as its soldered on the logic board. The SSD storage is changeable! You could try to locate a 16 GB logic board and swap it out but that will be expensive! Presently finding one is as easy as finding a Dodo bird ;-{ Due to COVID.
из Dan
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 22
