Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
451вопросов Показать все
MacBook is getting extremely hot
My Mid 2014 13” MacBook Pro A1502 is getting really hot when under normal use. You need to put a book under it to keep it from burning you.
I have plans to open it up and clean out any dust inside of it and I’m thinking it probably has something to do with thermal paste as it has never been replaced or opened in 6 years.
I wanted to get some answers on whether I should clean it out and if I need to replace the thermal paste. It doesn’t shut down or give me any temperature warning. It works fine although there are noticeable performance drops because of the heat.
Это хороший вопрос?
Оценка 0
Комментарии:
@jflys5000 - I think you need to install a good thermal monitoring app like TG Pro IT allow you to see things graphically, give it a try and post a snapshot of all of the sensors (make sure you get the bottom ones and the fan) post it here for us to see Adding images to an existing question.
Once we have it we can guide you on what's needed.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Open it up and look below the crimped end of the heat sink and see if you fins an oily looking stain. Sometimes these heat sinks leak and end up no longer working:
MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
HeyJacksonY будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 38
