Screen imperfectly sealed at the top
Hello,
I was recently given an iPhone SE (1st generation) in very good condition, the only minor issue was that the front facing camera had collected quite a lot of dust over the years, which would make pictures very blurry.
After an unsuccessful attempt to get that fixed in an Apple Store (they only offered a full replacement of the screen which was quite expensive and mostly unnecessary as everything else works fine), I opened it up myself, removed the dust (did not really have to fully disassemble the camera, just used a very thin opening pick and an air blower) and now the camera works fine and there is no visible dust.
There is no gap between the screen and the aluminum casing so the plastic tabs alignment is not to blame here, however the glass part of the screen does not stay fully aligned with the plastic rim that surrounds it (only at the top, not all around). Applying a light pressure aligns it but it does not stay in place otherwise. It’s only off by about a quarter of a millimeter but that’s enough for the smaller particles to be able to enter the casing (which is why, I now realize, so much dust had built up in the first place).
For now, I use a clear bumper case and open it up from time to time to clean the excess dust, but I’m looking for a more permanent solution: does anyone know how the plastic rim is supposed to stay aligned with the glass part of the screen? Do I need to change the adhesive or something?
Thanks in advance.
Это хороший вопрос?
